Racingsnake
Racingsnake Reader
1/18/22 12:20 a.m.
Any progress is good progress!
looking forward to seeing this go back together. Nice score on the lathe too.
SkinnyG (Forum Supporter)
SkinnyG (Forum Supporter) PowerDork
1/29/22 6:49 p.m.
I finally started digging into the rad support.  Rusty nasty bottoms were cut out, and I blasted until I ran out of sand.
And I finally finished these wall signs.  I plasma cut the pieces at work, but finally got them attached and painted.
1/30/22 8:59 p.m.
1/31/22 10:17 p.m.
And primed, letting it cure for a week before I weld in the patches:
2/6/22 11:04 p.m.
Patches welded in:
Next patches formed:
And primed, to cure for another week (you can see the shifter arm and the proportioning valve mount here as well):
2/14/22 1:23 a.m.
All this was primed, then welded in:
Also making changes to my solvent tank, which dissolved its second pump. Bought a skookum pump which will now be held in a translucent bucket, pumped up to the tank, and drained back into the bucket.
Rons
Rons HalfDork
2/14/22 2:46 a.m.
Don’t see Chinook used here often!
2/21/22 10:30 p.m.
Inner fenders mounted so I could tweak the door-to-fender gaps.
Not perfect, but if you aim for perfection, you'll never get it finished; Chevy aimed low, I can too.
Handy to use studs to hang the fender when you know you're going to take them on and off repeatedly:
Also made a bit to my home-made slide hammer to pull door and fender edges into alignment with each other.
2/27/22 8:00 p.m.
And just tried a bit of blocking on the walnut bag fender to see what would happen.  This looks promising.  Could build this up pretty easily with just more epoxy primer.
3/6/22 12:38 p.m.
Things are progressing too slowly.
I recently bought a Hyundai Accent to daily drive (36mpg) instead of my C10 (10mpg).  Our gas (premium, because 11:1) is $1.99/L, that's $5.50US/USgallon to you 'Muricans and £5.50/IMPgallon in the UK.  The car will pay itself off in less than a year in savings alone.  AND help me financially finish the '61.
Pops took a tumble recently, the second of significance, and that, coupled with a few other things has me looking for a care home for him as he's rapidly becoming unable to care for himself.  My goal was to have the interior painted over Spring Break, but we'll see what happens.
If I have to choose between focusing on the truck or helping my pops, I have to choose my pops.
I'll keep you updated when I'm back on the truck.
TVR Scott
TVR Scott SuperDork
3/7/22 8:31 a.m.
Sorry to hear about the aging parent problems.  I'm going thru some of that myself, so I can commiserate.  I hope you find a reasonable spot for him.
4/2/22 12:39 p.m.
4/2/22 4:38 p.m.
In reply to SkinnyG (Forum Supporter) :
I love seeing your updates. Always informative and entertaining.
4/4/22 2:02 a.m.
Began spraying the interior this afternoon.
While I am using a new charcoal mask and a relatively ventilated area, I'm not McLoving it.  I already have asthma; this ain't making it better.
I ordered a supplied air system.
NOHOME MegaDork
4/4/22 9:11 a.m.
You are spraying actual color already? You don't loiter about do you?
4/4/22 10:27 a.m.
Just the interior.  Then I need to focus on exterior prep for colour.
4/4/22 11:54 p.m.
Well, bugger.
PPG DelFleet gets mixed 6:1:1 (paint/activator/hardener).  For a semigloss, you would also add 3 parts flattener, so 6:1:1:3.
But like an idiot, I mixed the paint and flattener together, and then did 6:1:1 with THAT mix, which is too much.  This gave me a mostly gloss, not a semi-gloss.
So.... a scuff and a re-shoot and we'll see what it looks like tomorrow.
4/6/22 7:19 p.m.
Nope.
Note To Self: A nicer semi-gloss can be had with 6:1:1:4
And some colour:
4/6/22 8:30 p.m.
Recon1342
Recon1342 SuperDork
4/6/22 8:32 p.m.
Those door panels look sharp!
4/6/22 8:33 p.m.
Light gray is "Mouse Gray."
Dark gray is 2 parts Mouse Gray, 3 parts Gloss Black.
4/10/22 11:51 p.m.
Disassembled the hinges so they could be blasted and re-bushed.  I need to get two pins.  One for sure.
Then finished the door inners so that soon they can be sprayed gray and hung.
4/14/22 12:56 a.m.
I got two new door pins. Yay. They're too long, but that's easier to deal with than too short.
I now have paint - a quart more of Mouse Gray, two gallons of Grabber Orange, and a quart of an Off-White that goes good with the Orange. $1100 CDN.  Ouch.
Was going to shoot the gray on the door interior, but through a comedy of life doing me like it does, Ended up putting more primer down where I scuffed too deep.
Tomorrow I intend to shoot the doors.
4/14/22 8:56 p.m.
Mouse Gray. Hope to jamb the cab in orange tomorrow.
Shavarsh
Shavarsh Reader
4/15/22 6:13 p.m.
You're making good progress again! Just watched your alignment video the other day, very helpful, thanks for posting.
BbGdDz6FY6w2jjGw9pY1GIvc7n9eix6ZWOAclL9SPZUdZlKemXeKIjtUm9Sakzn3
