Update for no particular reason with a bunch of stuff that's been bouncing around my head.
Janel thanked me the other day for pushing her towards her little black car. Left to her own devices, she would have picked up a 2019 Grand Cherokee because it was so familiar. But she's really bonded with the car and has even started using the voice control.
We're still not driving much these days, but when we do it's the EV because it's just so easy. Something it took me a while to cotton on to is the fact that it doesn't need to warm up the way an ICE does. The heater works right away, there are no weird driving quirks as everything comes up to temp, no fast idle. It just goes. It's very easy to get used to that.
Something else I notice when jumping back and forth is how much I've come to use regen and one-pedal driving. I've altered my driving style so I never need more braking than the motors can provide. It's a bit like going between a stick shift and an automatic, you notice how the automatic doesn't have any engine braking. It's actually quite a good way of illustrating just how much energy you waste in an ICE when you can't recover any of momentum you've built up. It's quite rare I have to go for the friction brakes.
I had to make a run to Phoenix a couple of weeks ago, which takes me right through the middle of nowhere. When Monument Valley is on the way, it's a pretty desolate route :) Turns out there are Superchargers on the way so I could have done the trip quite handily in the Tesla, but since I was schlepping tools and wheels I figured it was safer to bring the big pickup instead of suffering the wrath of Janel.
The car is starting to show some signs of use. It's picked up a rock chip with a small dent right beside the headlight - those must be some thin fenders and/or a fairly high speed rock. Not much we can do about that, it's part of being a car. It also had a scuff on the rear bumper from a box loading mishap. My friend Travis is much better with a buffer than I and was able to bring it back. The fixed section looks so good I may have to wax the thing...
The car's continued to evolve a bit. There was an update recently that changed the interface on the main screen to allow for more useful real estate - it's a good redesign. A couple of icons got moved to the bottom row and the image of the car got bigger so it can better display cars around you. I'm not usually a fan of interface changes but this works better. Everything you use frequently is in the same place and there's more space for stuff you need.
Here's the new look.
Icons along the top are info. Icons along the bottom are permanent, they're basically buttons. Most of them have voice control equivalents.
From left:
Car settings (opens a window to adjust things like throttle response and just about every aspect of configuration, some of which is only accessible when you're in Park)
Audio control (opens a window to select source, station, play/pause, etc. Driver can control play/pause/skip/volume from the steering wheel)
Displays the rear/side cameras. Basically the same as if you were backing up.
Wipers (they're usually automatic and you can trigger a swipe with the stalk, this is for changing modes)
Carnet opens a secondary menu for stuff like streaming video, internet, "call" (which is an odd one), energy displays and generally the sort of stuff you use to entertain yourself when you're parked. I rarely use this one.
Driver seat heater
Fan speed
Set temp for HVAC
Passenger seat heater
Windshield defrost
Rear window defrost
Passenger's volume control (the driver has one on the steering wheel)
Here's what it used to look like. In both cases, when you're driving, the car on the left moves to a following view and it displays cars around you as well. Now it also shows street signs and traffic lights (you can turn both of those off) as well as 360* radar proximity so you can tell if something's close.
I noticed while riding shotgun the other day that the little picture of the car on the right side of the screen is detailed enough that you can actually see the little car on the screen in the little car on the screen when you're driving :) It zooms in like this when you're not moving. The phone camera didn't like all the pixels, but if you squint you can see it. This little car has been getting higher and higher resolution as time goes on. I swear it shows cloud reflections in the roof when you're moving.
